I have the CDR23 and no Bose, so I need to have the fiber optic loop activated via PIWIS. Dealer told me that he couldn't activate the loop without having the CDChanger actually installed, but from what I've read, that would then cause a problem when the Mobridge was connected. (Someone had this exact problem.)
Does anyone know for sure if the PIWIS system allows you to activate the CD Changer and save the setting WITHOUT have a CD Changer in place?
As far as I understand the unit behaves as it it was indeed a CD Changer. As for enabling a device on the unit prior to install on a CDR23 I am not sure.
You have to enable the CDC BEFORE putting in the mobridge. AND, to confirm, you can enable the CDC without actually having the CDC installed. The dealer did it for free in about 3 mins.
