Heya Loren, just wondering if you knew the part numbers for the studs and bolts and nuts that go into the exhaust side of the turbo. Aka hot-side to the cats? Also going to need to order a new gasket:(
TIA...
The studs (M 8 x 22) that come out of the turbos are: 900 081 059 00
The gasket is: 996 111 217 70
The nuts (for the studs) are: 999 084 052 02
and the washers are: 900 031 032 02
Loren yer' a life saver. Guess which fool broke one dammit:( Doing an exhaust swap...
