Anybody knows or use any hardware-software equipment, allowing to read values, and the main thing to change codings of Electrical system, Instrument cluster, PCM on 2003-2006, and 2008 Cayenne? Thanks a lot!
PS Durametric does not allow all needed features.
Edited by G_A
What do you want to change ? Without a PIWIS you can't anyhow.
No, for example VAG-COM allow connect via K-line and change coding of instrument cluster, as Belt gong on/off, C/F degrees, Ml/Km etc, but codings looks like a figure 00993884, change one sighn will change coding, but not so clear what exactly you change - You should be experienced in this procedure. Meantime this programm usually no connect to PCM via CAN and not allow change codings there (add or remove equipment? country settings, etc.)
PS Everybody should check connector pinout before try))
Edited by G_A
The Porsche OBD-II connector is wired slightly differently I understand.
No other toll that I am aware of except for a PIWIS tester.
Even then Porsche requires special codes (IPAS) on a per car basis to change some things or add some options.
What specifically do you want to change?
I am not about entering codes from ipas to activate some additional features, I just would like to have similar PIWIS menu to change country coding in PCM2.0/2.1 for example.
