I purchased a set of wheels spacers from FVD that came with the longer bolts. From reading on the H&R site for the spacers, it says you need to take the tapered piece that attaches to the oem wheel bolt, and put them on the newer longer bolts...
I was looking that the tapered piece this morning and it looks like they pinch the edge so it won't come off the wheel bolt itself....so is there a trick to getting the tapered piece off the bolt? or is it a matter of unpinching the edges so that it can freely move over the threads on the bolt....
Thanks in advance,
Will
People say they can just pry them off with enough force. You could also grind away the ridge on the bolt that keeps the piece from sliding off.
