I have a strange issue with the speakers in my '06 Cayenne S. I have the Bose system. When I drive the car with the sound system off, I occasionally get a very (I mean very!) loud "pop" out of the speakers. I haven't heard it with the system on. The system seems to work fine otherwise. It occurred only once over a big bump, but not the other times. Loose connection at the amp? I read in other posts that the amp is located in the cargo area, but where?
Any ideas about the "pop" and what may be causing it?
Thanks.
The amp. is located behind the right rear trim above the CD reader.
Thanks, but I assume you are speaking about the external CD changer, which I don't have. I only have the in-dash unit. Can you be more specific about the amp location?
The location is the same with or without CD reader, behind the separate cover in the trim, on the right side in the cargo area.
