Front Boot/Trunk light stopped working
Last guy who was pretty sure it was not the bulb - it was the blub.
The front and rear trunk lights use the same bulb, so swap them.
Also, if your front trunk is open and the light is not on, it will go on when you open the door or the rear trunk, unless the bulb is burned out.
Thanks for the posts guys - it was only yesterday, when I was showing the car to a friend, that i noticed the light was actually on, at the same time I had the rear boot open. When I last opened the boot, to see it not working, I had everything closed. relief !
