Hi guys!
I have a 98 boxster with 5 speed.
For the past year or so, I began to notice some funny smell inside the car, and it smells like mildew-ish. I also noticed the same smell from the vent on the side of the car.
What can be the problem? If it were coolant, I don't notice any drop in the coolant level.
Any input is greatly appreciated!
Hi guys!
Dsulu:
If it smells like mildew, it probably is. If it's coming from the air vents, you can sometimes get rid of the smell by spraying with a product made just for that purpose, and sold at all auto parts chain stores.
Just in case, be sure to pull up your carpets under the seats and inspect for any moisture in the foam rubber padding or floor or the car. If you do find moisture under the carpets, you have got to find the source of the water, usually clogged drains in the convertible top well.
Regards, Maurice.
