I am getting the oil changed next week for the first time since purchasing my '03 C4S, which I bought last month with 39,000 miles on it. (The prior owner had the oil last changed at 37,000 mi.). After this, I continue to plan on changing it every 3,000 miles.
I was wondering if anyone here knew how much oil the car should use in those 3,000 miles between oil changes? I would like to monitor the oil consumption.
Tommy, changing your oil every 3K miles is not only bad for your wallet and environment, but many expects believe is also bad for your engine, since "most" engine wear occurs early in the oil change cycle.
I would recommend changing your oil, with a Porsche approve oil, every year or between 7,500-10,000 miles, whichever comes first.
Porsche says 1 quart in 1000 miles is acceptable.
It amazes me how some Porsches "burn" this amount of oil (as normal) while others (mine included) never require oil addidtion between changes. I think a lot of this excessive oil consumption is an indicator of how properly the engine was broken in during the infant stages (first 2,000 miles) of ownership. Just MHO.
I agree on the excessiveness of changing a synthetic oil every 3,000 miles. I had a Mercedes E320, and using Mobil 1 changed the oil only every 7,500-10,000 miles and put 140k miles on the car and the engine ran great and didn't even burn oil at that point. My wife had a Mercedes SLK 230, and its oil change interval was 11k miles. After 7 years, the engine ran perfectly on this schedule.
More recently, we have a 2006 BMW 325i and its first oil change was at 16,000 miles. The engine, approaching 29,000 miles is ready for its second oil change, and runs perfectly.
With my Porsche, I plan on following the interval of changing the oil either annually of at 7,500-10k miles, but certainly no more often then that. It's just not necessary.
John
Wow, I didn't know that excessive changing of synthetic oil could actually be bad. My last car was an '03 BMW X5 and I changed the oil (also synth) every 5,000 miles and it kept things nice.
Maybe this will become an annual event since I only plan on putting 7,000 miles on per year.
As far as the synth oil to use, any recommendations?
Agreed. Just too wasteful and expensive to do it this often.
And...of course...Mobil1.
Tommy, I recommend you become a "Contributing Member" (great value here) then you can view all the TSB's. The TSB will list all of the Porsche approved oils.
FYI, I bought a used 2003 C4S, and add about 1 qt in 1200-1500 miles. I know it varies widely, however.
Thanks Jon - how many miles you got on it?
Hi! I purchased with 22 K miles last year, and have about 30K now
My 03 does not use any oil between oil changes (maybe a little, but not noticeable on the stick). I usually change oil between the 7-10k range. The Mobil One certainly does not break down in that range and could probably last a lot longer (oil gets dirty, but does not wear out in between oil changes).
Changing every 3k is a waste of money & an environmental issue (as said before).
