I've done a search and can't come up with anything. I've got the Becker keys and I've removed the pieces around the unit. I just can't figure out where to slide them in to get it out. :help:
EDIT: I figured it out, no need for Becker keys - Remove trim pieces on either side, unhook wire harnesses from switches and locate four torex screws. The thing is huge!!
Edited by Rob in WA
  • 7 months later...
I need to remove my PCM1 - see from the photo you have managed exactly what I want to do - I only need to slide it out to fit an iPod cable to the back.
Can you tell me how I can do this - thought I needed a becker key.
Many Thanks
