Hello,
I am installing a trailer hitch and downloaded the TSB pertaining to the install. It looks straight forward except it references '635019 - removal and install of rear bumper.'
Does anybody have this? or do you have any tips on the removal of the bumper or the install of the hitch??
Lance
Remove both tail lights, there are screws under the lights. Remove both inner wheel well partial, the bumper shell is secured on the rear wing with a screw. Remove the bolts on the lower part of the shell. Pull the shell backwards and disconnect the park assistant connector on the left side. Hope this helps.
