I have a 2001 Boxster 2.7 Tiptronic,
How do you tell the difference between a bad rear wheel bearing and a bad rear hub? Also, how can I determine which side?
This evening I jacked the car up and tried to shake the wheels and neither would move......
I have been hearing the medium level "roar" a little while now, I assumed it was because of the balding Kuhmo's I had on the car but when I picked the car up from the tire shop, my tire guy said that when he test drove the car he hear the noise and he thinks its a bad wheel bearing (possibly driver side but he couldn't really determine which side it was) He then said it might be a bad rear hub.
Not quite sure how a hub can be bad. Here is a picture...Maybe out of round? Bent?
Could it be the parking brake pads making the noise?
How many miles on the car? over 50k and i think the bearings will need to be done regardless.
