Hi everyone,
I have a 2001 TT and looking at doing a clutch on it soon as it is getting a EVOM stage 4 kit. Would anyone have the correct procedure for bleeding the clutch and the power assist for the slave cylinder?
Also i have noticed over the last few weeks the clutch pedal is alot harder in the mornings before i start the car is this the accumulator leeking? and should it be changed at the same time?
Thanks for ideas :renntech:
The clutch gets 'firmer' when the engine isnt running as you have no assist. If you turn off the engine and continually depress the clutch, it gradually gets firmer. Is this what you refer to? Dont think you have an accumulator issue, else it would be soft and pedal to the floor?
