I have a 05 997S Cab with Porsche sport exhaust option can I rewire it so the on / off works with out the dme kicking in when driving at low rpms, I would like to control it for quiet mode when I want . Thanks for any help.
Edited by clvig
Removed ALL CAPS - please do not post in ALL CAPS
I HAVE A 05 997S CAB WITH PORSCHE SPORT EXHAUST OPTION CAN I REWIRE IT SO THE ON / OFF WORKS WITH OUT THE DME KICKING IN WHEN DRIVING AT LOW RPMS,I WOULD LIKE TO CONTROL IT FOR QUIET MODE WHEN I WANT . THANKS FOR ANY HELP
Yes. Just run a wire from the fuse box to switch to relay in engine, or You can tap into the existing wiring below rear seat area. Search here or 6 speed for directions. You'll love it!!!!
Edited by larrytrk
hi i tried searching i had no luck can you give a link to it thanks
http://69.13.120.185/forums/showthread.php...ight=pse+bypass
#12
good luck! ck TSB's for install of PSE with wiring diagram!
#12
thank you so much
