Can anyone provide info on how to change the bulbs in the side view mirrors and bulb type - I have no idea why it is excluded from the manual.
JR
Remove the glass ( pull out ) and the rear shell to get access inside the mirror, the bulb is the same as the side marker and the possition light.
That's what I needed thanks RFM...
I am assuming if I pry carefully on the mirror it will "pop" out?
JR
Yes, pry carefully and the glass comes out. The light is mounted in the bottom part of the rear shell.
