Grab with a hook ( bended steel wire or similar ) under the left tail light, there is a emergency steel wire with a loop present in normal conditions.
How do I get under the left tail light?
Gato:
Go to this link and check out posts # 4, 10 & 11:
http://www.renntech.org/forums/index.php?s...296&hl=rear
There is a photo in post #4 of the cable loop, but it is a little difficult to see. If you enlarge the photo you can see it.
If you get your lid open, maybe you can take a better photo and post it here.
Regards, Maurice.
Gatotiger,
Like RFM said, make a hook out of wire and slide it under the gap of the taillight assembly. I have the day off today so I took a picture for you.
This will at least give you an idea where to fish for it. You should be able to grab it with some patience.
Hope this helps.
Philipj
I was able to lift the tail light a bit and using a flashlight I was able to see part of the cable, fished it and pulled the cable, lid opened!
Thanks for saving me time and money!
