If you have a crack in just the Cylinder Head,& not the Block!
is it possible to fix just the Cylinder Head without having to replace the engine?
& if so, what is it thats done???
Because the dearler who I got my 996 from said, that yes I was right that the car does have
Cylinder problems, & that because the car is not over heating, or smoking that it's more probably the
Cylinder Head & NOT the Cylinder Block. That the car needs just a new Cylinder Head
about €3000 & one week in garage. Is this right??? & can this be done successfully.
Any help much appreciated.
Thanks guys
Sometimes the cylinder head can be welded (a special process for alloys).
If not, then both the cylinder head and cam cover are replaced (as they are a matched set).
