So it turns out that my front bumper is a supercup front bumper which explains why it has the tow hook slot. i'm not sure if supercups have the bumper support bar, but it seems that this bar is right infront of the tow hook slat, so i'll have to cut thru it to secure the tow hook?
Does someone have a diagram or install directions from a supercup to show where it should be secured to?
TY
I don't think you can mount it without removing the front bumper re-enforcement - it bolts to the same point on the left side.
thanks loren. i'll look into the feasability of drilling a spot for it thru the rebar.
It not going to be in PET because it is a racing part. Racing parts are sold by Porsche MotorSports.
996.722.693.92 Towing Eye
996.722.801.90 Return Spring
900.075.457.02 M8 x 30 Bolt (2 required)
