Just plugged it in and everything worked. I thought I needed to have it programmed by the dealer. Any thoughts. I do know it came from a car similar to mine.(i.e. 2003 and coupe)
you probably still need to get it programmed in, even though it functions, in order to get 'full' functionality.
for example, you probably need that to get the OBC to display PCM nav instructions.
