I need to replace my faceplate........when I do, will I need to get a new code, or will the existing one work?
Thanks in advance everyone...
Gene L
As far as I know, the faceplate does not have anything to do with the code. You should be able to swap faceplates without a problem. Also, the CRD220 was in the 986 Boxster's, so this is the wrong forum. 987 Boxster's are 2005 and newer.
