Does anyone know the symptoms of a bad dual mass flywheel on a later 996? I hear a rattling sound when shutting off the engine (this is mentioned in the dmf service bulletin). Also, sometimes there is a rattle when accelerating right after coasting in gear. How responsive is Porsche to remedy a dmf failure under warratny? Any comments or suggestions will be appreciated.
There are several springs on the flywheel that sometimes break, often causing a rattle and abrupt clutch engagement. Putting the car up on a lift and then shutting it down will make it easier to identify where the noise is coming from. If a spring is broken, it is a warranty covered item.
