I reset the CEL after cleaning the MAF to clear P1128 and P1130 with my OBD2 scanner. It worked and the CEL is now out. Now when I run the scanner I don't get any DTC's, but 4 of the I/M readiness monitors are flashing. Do I need to run the OBD 2 Drive cycle to reset them? If so, where can I get the drive cycle process.
Thanks in advance.
Nope - you just need to drive the car until they are all happy faces. Sometimes this takes about about a week of normal driving.
I think that process is in there so you can't cheat on an emissions test.
I have one other question maybe someone could answer. If I hadn't erased the code from the car with the OBDII would the CEL have cleared itself after a number of trips? or is the only way to clear the CEL by using the OBD II?
2001 C4
114,000km
Canadian car
