Sorry tried searching....
can't seem to find instructions on removing/installing door pulls and door pockets
pyiu:
If your door panels are similar to those of a 986 Boxster (and I believe they are), go to this link for complete instructions and photos on removing the door panels:
http://www.ecoutez.net/boxster/door-panel-removal/
The only tricky part is the inner door handle/pull. This is the only piece that is a little tricky to remove without breaking off a tab that helps to hold it in place. Looking from underneath the plastic cover, you'll notice a small indentation in the center, towards the rear of that piece where it contacts the door panel.
You can work a small flathead screwdriver in there at the appropriate time, and, at that time, you can gently just separate it slightly from its contact surface with the door panel. First, though, put some significant pressure on the top (horizontal) rearmost surface of that plastic piece. Then, work the small flathead screwdriver in the indentation from underneath to separate it and then grab the whole plastic piece and rotate it upwards, pulling the bottom towards you and up, WHILE KEEPING THE DOWNWARD PRESSURE ON THE TOP REARMOST HORIZONTAL SURFACE OF THE PIECE.
Note that the pressing down while rotating the piece is what keeps the small tab that is under that section from breaking. From what I have read, they break 50% of the time, but if you do it this way, they will not break.
Regards, Maurice.
