I'm considering putting a 3.6L engine from a 2002 C2 into a base 2002 Boxster.
Can someone tell me if this is a simple swap and help with the questions below:
1) Do I need a new DME or can I use the same one I have.
2) Do I need to modify the headers? If I do, can I use the headers from the C2 instead?
3) Do I need to modify the engine mount?
4) Do I need to do anything with the E-gas? Does the 02' Boxster have e-gas?
Thanks in advance.
Actually, most of the conversion threads cover 2.5l to 3.4/3.6l. I have searched for a swap in an egas car too and couldn't seem to find it. Maybe I'm not searching correctly or something???
His car isn't an egas car. It started life as a 98 2.5l. I've read though that thread and the attached PDF and can't figure out the compatibility of egas 2000-2004 Boxsters with doing a conversion and what engine/DME combo would be easiest for an egas car. Thank you for looking though, I thought maybe I had missed something.
As Loren states all the information is there if you look for it. The 3.6 swap into a 2002 car is very simple.
1) no you have a 7.8 DME you just reprogram it
2) you can't use the 996 headers
3) yes, all 996 engines need to be lowered regardless of displacement
4) you have egas
-Todd
