Hi to all
It's my fist post on this forum ,and its because I have a big problem with my cayenne S 2003
the cluster give me this warning : electrical load swtch off ???
and with the durametric software I found code 907 but no clue about the trouble !!!
I check all fuses ,cannector on ecu and electric connection on generator and o cousre the battery terminal
I realy don't know what to do !!!! help me please !!!
I'm living in dubai UAE
:rolleyes:
This is normal if the engine is cut off and the ignition on after a short time. Let the engine running and clear the codes, the code can not been cleared with the engine off. As long as the engine is running ( the alternator load the battery ) the code will stay away.
