I've tried to install the OEM 17mm spacers on the rear and have ran into a problem. It looks like my 20" Techsport Wheel are not OEM (aka Knockoffs). And, the cut-out holes that the wheel bolt heads go into when you use spacers isn't as wide as the OEM wheels. It looks like I either need a lug bolt with a head that's less than or equal to 9.5mm or that's 15mm in diameter after the divergent part that seats in the bolt hole. Does anyone know of a wheel bolt that has a short head?
Any help would be greatly appreciated.
matt
