Hi gang,
I just had an annual service done and was advised of an oil leak.
They said it could trigger a CEL.
I gave them the go ahead to do it but can't find any labour charge relating to
it. They have fitted 996.107.237.52 and 2 hose clamps. Where abouts on the
car are they? The 996.107.237.52 has a brief description as BELLOWS FO.
Thanks.
Edited by HONEYMON57ER
The bellows is a rubber tube which connect the air-oil separator with the crankcase behind cylinder 3 ( on the left rear wheel inside area )
Hi gang,
Thanks.
THe part you reference is part of the oil separator circuit and if you had an annual with spark plug replacement, then getting to the bellows ( $15 part here in US) not tha tdifficult. It does require some removal of some parts like airbox to make access easier. Loren or another Porsche tech could give more specific time to replace bellows.
If you do a search for Oil Separator Bellows you should find more info as well.
Demosan :cheers:
