Replaced battery, now stereo is dead
Disconnect the battery ( + cable and - cable as well ), connect the loose + and the loose - cable with a jumper cable ( take care that the cables have no contact with the battery ) for approx. 30 minutes, reconnect the battery and try again.
It is a CDR23 - the car is a 2003 C2. At present, the stereo shows no sign of life at all.
RFM, are you saying to use jumper cables to make a loop of the + and - cables?
FWIW, the car sat without a battery for 4 days.
How do I get the stereo unit out to check its fuses?
Thank you all for the input - I truly appreciate it.
Bill
Bill
Bill:
To get the head unit out, you will need a special tool, which consists of two small metal blades that hook into each side of the head unit and which then release it from its mounting.
Regards, Maurice.
