I assume the shaft broke off in the hole.
I pulled the shaft out with a very small screw threaded in the broken end of the shaft. Then pulled hard on the screw and the broken shaft came out.
I remember that the shaft wanted to spin when I inserted the pulling screw, so I had to hold the shaft in place with a pointed object.
I had the same problem. on one, i got it with a screw. On the other, I drilled it out carefully.
Thanks - inserting a screw makes sense. I'll do it on Saturday and see how it works.
