ok i have a 2002 996 tt i have cargraphic exxhaust and ecu flashed bm short shifter k24 turbos gt2 intercoolers i cant hear my turbos at any time i see vidoes of other porsches and thee turbos sound like jet engines and im really upset my car doesnt sound like that is it my exuast or what even at dead stop reving the engine i cant hear them whats the deal plz help ty :P
You wont here them just stationary reving the engine (neither do i) but i suspect as you have a 'louder' exhaust on your vehicle than standard, that may cloak the noise. I dont hear mine much either when i open the taps, a slight whistle but thats about it. Remember the turbo's cloak the noise of the 'true' flat 6 and your 'loud' exhaust is probably masking the turbo whistle. These cars arent Subaru's or EVO's with loud dump valves etc etc, these are refined cars........
Incidentally, are you hitting your boost pressure???
You're kidding right. I sure hope so. Do you understand how your turbos work? Your turbos will not produce boost when revving the engine at a stop...watch your boost gage next time.
yes i know turbos wont spool at a dead stop but i see videos of guys just reving there engines and you can hear them but to answer your question of boost im getting 0.9 but i still need to recalibrate ecu for 1.1 but other then that im good to go
maybe it is my exuast it is loud should i go with diff exuast ? or should i put a diff air filter setup mine is still stock the guy who did my car said it was awaste of time so i left it stock plz help ty
I have the Europipe setup, and between 3000 and 5000 rpm, I can hear the turbos whistling....but the Europipe isn't really a loud system, I think WOT is 103db....so the comment about your exhaust system masking the sound could have merit. I'm running stock everything except Diverter Valves on an X50.
