I have a set of HRE 890R wheels with the valve stems inside the spokes. Pumping air at gas stations is difficult because most nozzles won't fit thru between spokes. Is there a tool (like an extension) or tricks to make the job easier?
Thank you.
Hi there , I have similar HRE wheels, you should be able to get an extension from any good wheel shop I have both plastic and metal ones and both work well
Thank you for the info. I'm in the Bay Area and am not sure what kind of "wheel shop" you mentioned. We have tire shops here, but pretty sure they don't sell extensions. Do you have a picture?
Hi , I don't have a picture but all that they are is a tube extension for the valve stem, if you show your wheel to a tech at any quality tire or wheel store and tell them what you want they should be able to help you out.
