My left side exhaust is rattling again and this will be the fourth time I have had the exhaust system addressed with my dealer. I had my dealer install the PSE when I bought my car brand new from them and was wondering if the PSE may be the culprit here. The first time the dealer replaced the RH Cat Conv at 15156 miles. The second time the LH Exhaust Pipe was replace at 25924 miles and the last time the LH Exhaust pipe was replaced at 41619 miles and it now has 44573 miles on the odometer. I would also like reasons and suggestions that might cure this recurring problem that I may suggest to my dealer because I'm pretty sure they are just fixing the broken part and not looking for why it caused the part to be broken in the first place. Can anyone help because I need the problem fixed. :o
TIA!
cracked welding on the tail brackets. I had to replace left and right 5k apart (cost about $40 each, while dealer said he will only replace the entire system at $600+). it is the last portion of the exhaust pipe (the one under your C4S chrome tail pipe ends). you will not see it even when it breaks. if this sounds like your problem and you cannot find, write back
