Does anybody have diagrams or pics of the following parts?
Hello all I just got an 02 C2 Cab and it has the areo cab wing and side skirts. I am contemplating adding a spoiler lip under the front bumper. Seaching on the topic I found 4 different part numbers. I talked to Rik at Suncoast and asked him about the parts, but on his order screen there wasn't a diagram.
Does anybody have a diagram or a picture of the following part numbers?
996-505-986-02-G2X - this appears to be the front lip for the areokit II front bumper as it comes primed for painting
996-505-555-01 - this appears to be the rubber front lip that goes with the aero cab rear spoiler and should be a direct fit to my front bumper.
996-505-986-92-01C - GT3 rubber front spoiler lip. I have seen pics of it, but I don't like the fact that you have to cut the ends off as it hang into the wheel wells.
It also seems that the GT3 cup lip spoiler will work but I am not as sure I like the looks of it as much. Part number for that is 996-505-986-90. I have seen pics of this.
Thanks it advance!
Shawn
I think you will need to change the bumper to fit the other front spoiler lip.
Probably best to confirm exactly which front bumper you have - because dealers are not supposed to add the rear spoiler without the adding the front bumper/spoiler.
The correct part number for the Aerokit Cup II front bumper is 996.505.986.02.G2X.
Thanks.
I have a stock 02 bumper.
I will post what I end up with including pics :)
Thanks it advance!
Shawn
Do you know the manufactor date of your car? There is a Carrera Aerokit for cars manufactured through 7/01. It is for the cab or coupe. The front bumper on this package doesn't look that much different than the stock. You can see a picture here http://www.pelicanparts.com/catalog/shopca...tec996_pg28.htm Are you sure yours is stock? Like Loren noted the rear spoiler is not suppose to be installed without the front.
Will
Will
Don't know the manufacture date, but it is an 02 so post factory shut down and post 7/01.
Stock 02 front bumper. Aero cab rear spoiler and side skirts added after it left the factory, because it is not on the build sticker.
I ordered the rubber front lip that is part of the Aero Cab/carrera kit that is a made for 02 face lifted/MKII front bumpers. I know the GT3 rubber lip will fit with some trimming, and it looks great and is reported to work well. I ordered the part I did to see how it looks/works since I know the GT3 lip will work, but don't know about this one.
From what I gather, the 02 face lifted front bumper aerodynamics are enough such that you can can just add the aero cab/carrera rear wing.
I ordered it from Suncoast today so I should have it in about a week. I will post pictures and let you know if it is a direct install.
Update
I ordered the following part:
996-505-555-01 which is apparently the front lip spoiler for the Carerra Aero kit also know as the Aero Cab kit.
It is a direct install into the underneath of an 02 bumper.
Turns out I already have one of these on my car :oops: :cursing:
Here are some pics of the part.
