I had my car (99 996 C2 coupe) idling for about 20 mins this morning, and noticed that both exhaust pipes, in addition to maybe more exhaust than normal, had also been dripping water. (NOT coolant- it was not sweet, nor orangey in colour) The amount would probably be a total of about 1/2 cup per side. I watched things progress, and there was a consistant two - three drops per minute. I drove the car around the block, and the same problem kept occuring.
Is this normal?
Also, I noticed that at idle, my oil pressure was only about 2 bar or so. When the revs were increased, the pressure went almost immediately up to 4.5-5 bar.
Is this normal?
Thanks for the help- I am obviously new to the Porsche world and this site is a great resource! Thanks again.
This is all normal, 1 L fuel = 1L water. Ones the engine is warmed up and the mufflers hot, the steam will disappears. The oil pressure looks OK to me.
Is this normal?
Is this normal?
I agree with RFM. These have an air pump on them, add that to cool dense air and Voila' you've got lean steam.
