I need to hook up radar detector unit (I am in Taiwan) it should be installed behind front grill toward to the front.
I need to know the easiest way (direction) to reach behind front grill. (Not necessary to take off the whold bumper off, but just my hand and that radar unit to go behind that grill)
Thanks in advance.
The easiest way to have exes behind the central grill is still removing the bumper, if you can do the job in the front side grills area ( above the fog lights and the claxons ), you have only the under plate and the small flaps to remove.
"Access" behind the central grill looks better. Sorry.
Thanks for the reply.
Let me make it clear, from your reply, if I want to access to the center grill, then I have to remove the front bumper.
If I just want to access the LOWER side grill section then just remove the under plate, the bumper stay on the car right?
Thanks again
Right, the under plate and the small flaps beside. This is also the way to change a bulb in the fog light and to remove the claxons on a Cayenne V6 and S. Turbo's are differend.
