Just pulled the water pump off...what a fun job..looked at it and only 1/4 of the black propeller was there...no sight of the other 3/4 of it...where should I look for the rest so I don't end up with a blown engine. I did drive the car back home, about 3 miles when it went bad, so where ever it will go, it may be there already. Need to put it back together on Sunday...Thanks
I had this happen once on a 986 but loads of time on VW's. I collected as many of the pieces as possible but sure I missed a few.... so far so good with no problems. Try your best to find them but don't lose any sleep over it.
Look in the thermostat housing, some propeller pieces get stuck between the thermostat valve and the body.
Zman:
Bummer! It might be a good idea to reverse flush the coolant system and collect the water that comes out to see if you can "piece together" the impeller blades that self-destructed. If you can hook up a hose nozzle onto one of the coolant system hoses and seal it with a hose clamp, you should be able to get a strong flow.
Here is a diagram of the cooling system showing the direction of flow of the coolant at the following link (See post #17):
http://www.renntech.org/forums/index.php?s...ic=18078&hl
Regards, Maurice.
