Hi, I have located the DIY article for Boxster seat belt replacement but have had no luck finding this info for my 997. Is it pretty much the same or totally different?
Don
Don, make sure to use Lock-tite on the bolts when you re-install.
Thanks White! Are you saying that the job is the same for both 987 & 997?
Don
