Just a simple question, whats the ideal tire pressure on stock gt3 mk1 wheels on a hot day? And whats the best tire pressure when i bring it to the track? Thanks in advance, peace! :renntech:
Hmmm The US did not get the GT3 MKI, so, you may not get many US responses. UK guys??
It may help to know what tires you run on the street, and especially, what on the track? PAG changed the recommended pressures and tire sizes on the MKII that we did get in the US.
  • 3 months later...
Hi, I follow the recommended tyre pressures of 32psi front and 39psi rear. I measure these pressures late at night when it's coolest. I don't bother messing with the pressures even when I track the car and, its worked fine for me so far.
  • 4 weeks later...
I run 25psi (1.723 bar) cold on the fronts and 23psi (1.585 bar) on the rears in my MK1 but I use semi slicks.
I usually run around 30psi hot and modify it accordingly on the track
  • 4 weeks later...
Tire pressures on the street with street tires, I recommend you follow the Porsche Owner Manual.
Regarding driving a street tire on the track. It's not recommended to drive with under inflated tires because of several reasons. So you should start driving the car and continuously release the pressure once it starts to go up. Don't go out on cold tires.
