Can someone ID these components? What would have been in the empty spots? How often would the #6 socket be used and would covering it with the MSD CDI unit be a big problem? My '86 911 turbo
1 and 7 are not used
2 and 3 are fuel pump relays turbo only
4 heater blower relay
5 relay window defogger relay
6 is the plug for the idle control valve by pass tool, no longer made.
so blocking it should not be a problem
Thanks for the info
