I have the wood trim option in my 2000 C2. Problem is in several, but not all, areas it is or has disintegrated. Just under the front window it became warped and cracked. Does anyone know where I can find replacement pieces and not have to buy the whole kit?
I found a copy of the "T" equipment options (Probably from a link here at Renntech, but do not remember for sure). I tracked down one trim piece (door pull) and the dealer was able to order it. Some are parts of kits and some are not. Pretty amazing,however, was the fact that the finish of the part I received in 2007 matched the original 2003 just great. Good luck!
  • 2 months later...
Check with dcautomotive@gmail.com I got a Rootwood door handle replacement from them at about half dealer price. It seemed to be factory part and brand new. I suggest you get the exact part number from dealer to ensure it's the right piece. Also, if they don't have it Google the part number and see what you find. Good luck.
