I have a CD Changer - CDC 3 - fitted and when I first got the car it wasn't working. I took it out and reconnected it and all was well! However, I recently needed to disconnect the battery (to mend door handle) and now it's packe up again! I'll try disconnecting it and reconnecting - as before - to see if this sorts it out. Is it usual for this to happen when power is disconnected? The changer appears to work okay otherwise but does have a broken/missing cover.
Trevor
