Hello:
Well i unfortunately think i have hit the point of needing to change out the clutch tin my C4. Question is with it being AWD does it ruquire more work to get the trans dropped out (disconnect the front diff) and if so what kind of time can i expect to have to pay for. From what i gather an experienced tech can do it in most rwd cars in around the 4-6 hour range. Is this the same for the C4?
Another thing is since im going to bring them the parts what do you guys suggest as far as a parts list? Are there any tsb's from porsche that i should address while the trans is out? Thanks for your help in advance.... :renntech:
