I have a 1999 996 C2 and the right headlight is dim but not out when headlights are on. It is the same sort of dim as when you have the parking light on or turn off ignition with lights still on. My question is since it is still dim and not out would it be the actual bulb that is the issue or perhaps the headlight switch or a connection?
A bulb is only $12 or so and I found howto which covers replacing the bulb (http://www.bombaydigital.com/boxster/projects/headlamp/) would this be a good first step to troubleshoot it?
A dim headlight is usually a bad ground connection. Remove the headlight and check for corrosion at the connector. Good Luck.
