ok guys, i am totally lost. i have seen other similar posts that describe my problem where when i trun the key everything lights up but engine don't start. all sugestions are looking at the clutch interlock switch. i got down and looked around the clutch, and the only part that i can remove is i believe the clutch cruise control switch. its got a push switch at one end on the clutch padel side and the red cruise control connects to the other end. i do see a steel plate with two wires connected to it. is that the clutch interlock switch? if it is, it can not be removed and cleaned like some people have suggested.
i am not sure if my problem is the clutch interlock switch. even though i have exactly the same sympton, but if i turn the key and hold it for 5 to 10 seconds, it will start. but it is getting worse. last few days, i have to try 4 or 5 times before car starts. each time i have to turn, hold it, take the key out and put it back in and repeat for the car to start. can this be something else? please help a 2000 s. :(
Unless someone took yours out, you cant miss it, grab the first 2 wires you see (on or near the clutch arm) and pull them off and jump them together with a little piece of wire. If your car starts….
Regards, PK
If you still don’t get it, push the clutch with your arm and see what’s happening
If you are able to turn the key and get it to start (eventually) I am guessing it is the ignition switch, especially if it continues to get worse.
E
