Is there anywhere to look up and get further information about the fault codes Durametric extracts from the onboard? It would be really nice if I could just click on the fault codes (assuming I'm also attached to the web) and get further info.
Also, I had a misfire and engine check light on my car, I replaced the coil pack and fixed the misfire, but I can't get Durametric to clear the fault list and check light. I'm assuming I've done something wrong, but I'm not sure what as it is. I'm using the latest version (4.3.3.0).
Trevor
Calgary, Alberta
Edited by trevorc
..................... I'm using the latest version (4.3.3.0).
Trevor,
Go back to Durametric's website for the latest version: 5.0.1 (beta) -- current as of 1/30/08. They have also provided a user's manual.
Regards,
paul...
Trevor,
Regards,
paul...
Thanks Paul I'll check it out, although I'm always a bit hesitant about beta code... ;-) But will watch the site for a GA release.
Trevor
Calgary
