The following fault codes show up on my 996 after I flashed it with a new engine program and can't be cleared (clear them and they come right back). They were not present with the old program. Nothing else has changed in the car. Any thoughts?
Motronic 7.8 Current
P0413 Porsche fault code 85 - Driver elec. switch-over valve Secondary air
P0418 Porsche fault code 84 - Secondary-air pump
P1674 Porsche fault code 497 - Final stage engine compartment purge fan
VMAN
P0413 Electric change-over valve - open circuit
Possible fault cause:
- Wiring harness
- Electric change-over valve
- DME control module faulty
P0418 Secondary air injection pump - open circuit
- Wiring harness
- Relay faulty
P1674 Engine compartment purge fan output stage - open circuit
- Open circuit
- Relay faulty
Do you do an adaption for the DME after programming?
Switch on the ignition
- Wait one minute. Do not press the accelerator
- Switch off the ignition for at least 10 seconds
- Read out the fault memory
Check the fuses and the relays - otherwise you may have smoked the DME.
- Wiring harness
- Wiring harness
- Relay faulty
- Open circuit
- Relay faulty
