Part Number for Seat Belt Buckle Wires
The ones I've seen/installed came with everything except the bolt.
Loren,
Is this the right part?
http://e-partssales.com/Merchant2/merchant...ry_Code=986seat
It's for the 986, but looks the same as mine...
Tom
Loren,
I found the parts at Sunset. They have both driver's and passenger's side. It was $52 for driver's side and $40 for passenger. The bolts were $0.99 each. (I'm glad you mentioned them!)
Thanks again! You should get a raise ;)
Tom
Loren,
Tom
Loren,
Tom
Tom:
Are you replacing the seat belt buckles because of an airbag light problem? If so, you will likely need additional parts to get rid of the light (aside from a Durametric, PST 2, or PIWIS).
Loren,
Tom
Loren,
Tom
Tom:
No, I am not replacing them. I am putting the new receptacles on my track seats so I don't have to swap them each time I do the seat switcheroo. Just 4 bolts and an electrical plug.
-td
