Park assist and reverse light don't work on a C4S
Hello,
The reverse lights and park assist don't work suddenly on my 04 C4S TIPTRONIC.
Where is the sensor located ? Is it on the gearbox, or on the tiptronic lever ?
I checked the fuses and all seem well. Is there a relay I should check somewhere ?
What else should I check ?
PLEASE HELP URGENTLY
Hello,
It's more than likely to be the switch on the gearbox.
It was the contacts on the tip lever that were bad. We tightend them up a bit, and all is ok now. Strange thing is that the switch unit is made from Delphi. Weird if find this on a Porsche.
thanks for your help
