I saw some of these on ebay but was wondering if any of you had them on your boxsters? I need a set because here in Texas they are needed. Any suggestions of were else I can find them? I have a speed yellow 2004 boxster. Thanks in advance
Most people just make their own using either plastic or wire mesh from a local home improvement store and hot glue or epoxy them on the back side. You can pull the bumper cover off easliy and trace for a custom fit (search "radiator cleaning" or "bumper cover" for instructions). Remember though, since you're in a warm climate, if is you use too tight of a weave you will affect the air flow and cooling capacity of the radiators.
Yup, I replaced the grills in my bumper with mesh screen for like $13 from Home Depot. I took the bumper off and mounted them from behind using zip ties and a few strategically placed holes that you can't see from the outside... No temp issues for me, but I live in Northern California. It only gets up to 114 F here in the summer. :)
