I have a MY2002 Boxster 2.7, and the radiator cooling fans seems a lot louder than they ever have. I understand that the radiator cooling fans work on two stages:
- Stage 1 when coolant temp > 100 deg C or, there is an A/C demand, the air intake temp is > 8 deg C and terminal 15 is switched on.
I take this to mean 'Stage 1 under normal driving conditions with the A/C turned on'.
- Stage 2 when coolant temp > 105 deg C, or the refrigerant pressure in > 16 bar.
I tak this to mean 'When it gets very hot', although I'm not sure of the second part. What would cause the refrigerant pressure to be > 16 bar??
My radiator fans seem to be off when the A/C is off and the car isn't hot (to be expected), but then jump to Stage 2 when the A/C is turned on.
Any ideas, things I can check?
Charles
