Hi !
Can Anyone tell me can I put a US 2006 PCM unit + US DVD navigation unit to my Europe 2003 Cayenne Turbo which has only CD navigation?
Is It going to work without any error(radio frequency can be all ex.:FM 90.1MHz and 90.2MHz can be seen also?)?
Thanks and best regards for All !!!
Edited by barogabi
  • 2 months later...
Hi !
Hello, Can you let me know if it did work ? I have the same issue and it says Error .
Hi !
You have a DVD based PCM to be put into a CD based Cayenne? I'm going to say you can safely expect multiple errors, if it works at all. If you're adding the DVD nav unit also, I'd love to see how you mount yours; I looked into it and I would have to replace the entire seat it was to be mounted under.
